jip
#1 Posted : Saturday, April 30, 2016 5:11:41 AM(UTC)
jip
Estonia
Is it possible to enable saving a duplicate of the streamed content to a file on a local disk?
I presume this would be the optimal solution for creating a backup of the broadcast regarding CPU usage. In such cases it would not be necessary to use the Recorder, unless the required quality or format would be different from the stream (h264).
I believe FFMPEG has this as a built-in function, so implementing this would not cause substantial changes?
https://trac.ffmpeg.org/ticket/1382
