halfpipe
#1 Posted : Wednesday, December 5, 2012 7:30:15 PM(UTC)
halfpipe
Will be using Vmix next week for the very first time at a performance after almost a year of casual practice.
I'm unsure as to which of the Bit-rate recording options to use. I'll be creating both avchd dvd (1920x1080) and sd DVD nstc 720x480 from the recorded file so which would you use 16 or 25 Mbps?
thanks
Bruce
#2 Posted : Wednesday, December 5, 2012 11:51:43 PM(UTC)
Hi Bruce,
For high quality archival of HD, the best option is 50 Mbps
25 Mbps would be the very minimum for HD.
