Fullscreen drop down selection
In earlier versions (16 perhaps) it was possible to drop-down select which input to use for Fullscreen (right part of the Fullscreen button). This is not possible anymore.
Joined: 3/7/2012(UTC) Posts: 2,683  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ richardgatarski
Does not appear to be an issue for me, the dropdown for "Fullscreen" choices seems to work fine for me in vMixHD 17.0.0.77 x64. Maybe it's a version issue?
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
On my system, the drop down does not appear until after I have connected an external monitor AND have clicked on the Fullscreen button at least once.
Joined: 11/30/2013(UTC) Posts: 165 Location: Seoul, South Korea
Thanks: 39 times Was thanked: 19 time(s) in 14 post(s)
It would still be nice if this dropdown showed the input's name instead of Input1, Input2, etc... My two cents.
Sorry, my bad - seems it's been and is that you can only select a source if there is an external display attached. Still, I think it would be useful (albeit not necessary) to specify a source in situations you prep w/o a display.
And I agree with ibgaus and others, having the names insted of input number would be great.
