Rinsky
#1 Posted : Thursday, April 28, 2016 4:19:24 PM(UTC)
Rinsky
Is it somehow possible to also use the smartphone tally lights over internet?
ask
#2 Posted : Thursday, April 28, 2016 6:21:23 PM(UTC)
ask
Yes, but you need to make your production machine (webserver) visible to the internet. This can be done by port forwarding on your router, or by putting the machine in the DMZ. Please see your router manual/s for details. Note: there are security risks here so be sure that you are comfortable with it.
Rinsky
#3 Posted : Thursday, June 23, 2016 8:12:49 PM(UTC)
Rinsky
I tried both, port forwarding and putting my machine in the DMZ, both didn't work. Any other tips?
