Gene Norman
#1 Posted : Tuesday, April 26, 2016 3:59:10 PM(UTC)
Gene Norman
Get the following error when trying to record in MP4 format. "Recording stopped unexpectedly" RE.Recording
Exception from HRESULT: 0xC00D36BB
VMIX 17.0.0.76 (64)
Hardware: HP ZBook G2 Intel I7 4710MQ at 2.5ghz
8gb RAM Windows 7 Professional (64)
Nvidia Quadro K1100M
Intel HD Graphics 4600
Sonnet Express SE-I PCIE Thunderbolt Enclosure
Magewell PRO PCIE Capture Card HDMI
Worked fine with latest VMix 16
Really need to be able to record in MP4.
Any ideas for solution?
Gene Norman
#2 Posted : Tuesday, April 26, 2016 4:47:52 PM(UTC)
Gene Norman
Just got fix from Martin at Vmix via email. Unticking checkmark in "Hardware Encoder" record settings fixed problem.
Thanks! Martin You are Awesome!
Guest (4)
