vMix + NewTek NDI Connect Pro = Key + Fill output?
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
http://www.newtek.com/software/ndi-connectI/O card support includes: AJA, Blackmagic Design, DELTACAST, Magewell, Matrox, Teradek Cube, DirectShow devices, webcams, and USB3 capture devices; all common audio capture and output devices including professional audio cards, AES67 and Dante (which might require additional install from manufacturer). Support for key and fill input and output on appropriate video cards.Costs a whopping 1000$, but will it be possible?
You can download a free 2 input version from Newtek. This allows you to test the functionality before spending anything. And wil probably be enough for most use cases.
Use the free version to test. But for $995 you get a lot more than just key+fill. Think of NewTek Connect Pro as a real-time (just about) anything to anything conversion tool.
Double the number of inputs, plus a fifth NDI monitor for viewing any NDI source on the network. Dual monitor support Support for other IP input formats (IP cameras, web streams) Video and/or Audio delay (millisecond timing) Additional audio channels (up to 8) Color Correction tools with scopes NDI Web Server, a multiview that you can pull up on a web browser to view any NDI stream on your network (this is very cool). Clip playback with autoplay support and looping. And more to come!
Kane Peterson NewTek
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
A word of warning before anyone is thinking of buying NewTek NDI Connect Pro.
Please make sure your CPU can use this software as I downloaded the demo/free software and tried to install it and I got a message saying 'NDI Connect requires a CPU with AVX instructions'.
I have an old Intel Core i7 950 @ 3.07GHz processer and it does not use AVX instructions so make sure your CPU does before buying NewTek NDI Connect Pro.
 1 user thanked Len56 for this useful post.
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
Thremir wrote:http://www.newtek.com/software/ndi-connect
Costs a whopping 1000$, but will it be possible? As an alternative, you could use Sienna NDI OutletmacOS, supports BlackMagic design interfaces and cards, outputs fill and key from NDI and incredibly, at present, only costs $50...
livepad wrote:As an alternative, you could use Sienna NDI OutletmacOS, supports BlackMagic design interfaces and cards, outputs fill and key from NDI and incredibly, at present, only costs $50... Cheers, but I don't have any computer running OSX...
