Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
I know the pre-4k models are supported, but can anyone explicitly say if the Intensity Pro 4k model works/is supported with vMix?
Thanks!
Joined: 8/3/2015(UTC) Posts: 323 Location: Chicago, IL
I can confirm the 4K Intensity pro works with vMix.
 1 user thanked Cpilcher for this useful post.
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
Works, you just need to make sure the card is in RGB mode
 1 user thanked Lennart for this useful post.
