2 Pages<12
RoboST
#21 Posted : Friday, June 24, 2016 4:39:01 PM(UTC)
RoboST
I checked the BCC950 attached to the PC running vMix and I created the Input with default, vMix shows it 1280x720 RGB24 (using 30p)
The only others available at 720p are MJPG and I420, both inferior to RGB24, RGB24 has the lowest Render time and CPU usage in vMix.
The local c920 (Logitech drivers) defaults to RGB24, I'll check what's available.
EDIT: Same options as the BCC950 for 720p (30p).
Guest (12)
2 Pages<12
