Mari
#1 Posted : Thursday, March 24, 2016 1:23:16 PM(UTC)
Mari
Netherlands
Searched the forum but couldn't find an answer, problably because English is not my native language and I probably use the wrong search-texts.
When I stream to YouTube I get "black parts" at the top and bottom of the screen, like watching widescreen on TV.
How can I remove these "black parts"? I'm sure it has something to do with some settings, so who can point me in the right direction?
SpelingMistakes
#2 Posted: : Thursday, March 24, 2016 1:51:44 PM(UTC)
SpelingMistakes
Try to scale whole video or to change aspect ratio (source, Normal, anamorphic, wide) of input source which you have on the beginning of every project (input section) – Just below name
Size can be changed in position tab
That can be only part of solution because we don’t know where is problem – in streaming or in input video from your cameras
Bandit62
#3 Posted : Thursday, March 24, 2016 1:54:53 PM(UTC)
Rank: Guest
Groups:
check your settings for aspect ratio, 'Settings > Display > Output Size, and Aspect Ratio...you have the choice of Normal, Widescreen and Anamorphic...I usually choose Normal ....... and if that does not solve it, do the position thing....Click on the little Cog, choose 'Position, and adjust the Zoom Y, until the Black edges disappears..I have to do that sometimes with some video clips......
