We've got 2 studio's where we have floormonitors to display video. Because the hosts are not very experienced presentors for camera, they don't want to see themselfs on screen.
But i get the request to show the video in the studio when we play one. Now i can put 1 video to be on external 2 but if there are multiple clips, it's not possible to show them all.
In my case it would be great if i could put the clips in a playlist and use the playlist as a source for external 2.
Or has somebody a better idea for this?
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
I do something similar, while using a list input. I can select the appropriate video from my list input and select only that input to go to my external 2. In the settings, go to display and select input, then select the desired input. There may be a better way to do this but it is all I have needed up to this point.
 1 user thanked Cpilcher for this useful post.
