Joined: 3/9/2016(UTC) Posts: 33  Location: Cotswolds, UK
Hi Guys,
I am already a VMIx customer.
I am looking at buying the following and would really appreciate your feedback on how well Vmix will run on it please. I will be running it in bootcamp.
MacBook Pro 2.9GHz Dual-core Intel Core i7, Turbo Boost up to 3.6GHz 8GB 1600MHz DDR3 SDRAM — 2x4GB 1TB Serial ATA Drive @ 5400 rpm
Inputs 2 x Pro cameras inputted via external Magewell products via USB 3. External picture output via Thunderbolt through a BlackMagic Ultra Studio Mini monitor to a VidIu for TX.
Do you think the internal HD will be OK for recording the live feed or would I need to replace it for an SSD?
Do you think Vmix could cope with the two cameras in full HD and VT's etc?
Joined: 10/29/2013(UTC) Posts: 57 Location: Conroe TX
Thanks: 6 times Was thanked: 5 time(s) in 5 post(s)
I'd definitely be looking for an SSD. The performance gap between the 5400 rpm HD and the rest of what you have is very significant.
Good Luck
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
