Thanks: 23 times Was thanked: 13 time(s) in 10 post(s)
I've run across a bit of a problem with the way instant replay calls up the stingers for transition in/out.
When my replay tech plays a replay, it calls the Stinger up in overlay 1. There are two problems with this. It impacts the overlay already in overlay 1, and I can't add the Stinger to my external output (which is a clean feed that only carries overlay 4.)
My scorebug is always in overlay 1, my info graphic always comes up as overlay 2, overlay 3 is open, overlay 4 is used for social media title graphics. Of those, only the social media titles are needed on the in house feed.
I used setting —> outputs to turn off overlays 1,2, and 3 for external.
The client complained that the wanted to Stinger transition to fire into and out of replays. However, I can't do that.
I've looked in the overlay settings and in the instant replay settings, neither over me the ability to assign that overlay the Stinger(s) in.
Is this a missing feature, or am I missing a setting somewhere?
Not sure if I'm providing the right info. Too early in the morning for me at the moment and not fully awake :) But Stingers have there own overlay channel and don't interfere with the other 4 overlays
Click on the overlay button at the bottom taskbar Select the number dropdown and select stinger 1 set duration, stinger cut point and select the stinger
In replay select the stinger 1 or 2 as the transitions.
This should not deselect the other overlays.
Let me know if that is what you were asking.
The replay stinger will fire before and after the replay. You can add additional overlays to replay input like a Replay title that slides in and out during the replay so people know they are watching a replay and not live action. or a sponsor replay logo etc
