  Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
                Hi All I just bought up a PTZs camera from ebay. The seller advertises at as working in VMIX as an RTSP input and yes video and audio comes in fine and nice quality ! I compared it with a Teradek cube and latency and video quality is pretty good.  link here: http://www.ebay.co.uk/it...4f587:g:3yUAAOSwUuFWxg-u
              1 user thanked Jagawave for this useful post.
 Joined: 3/30/2011(UTC) Posts: 308  Location: Portugal Thanks: 347 times Was thanked: 35 time(s) in 30 post(s)
                How about NDI support firmware update ?
  PZT optics said it will do it.
  can this brand do the same ?
  Cheers,
  PFBM
                I don't think its a clone. My guess its the same OEM camera but PTZoptics have put their branding on it and perhaps developed custom firmware. RE the NDI feature I was not aware of that but will ask. At the moment I don't have a need for that though as it works fine as an RTSP input in VMIX. NDI looks good though.. I did check out Globalmedia also but after shipping and taxes it worked out better getting it from Ebay and the seller accepted an offer:)
 Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
                Jagawave wrote:I don't think its a clone. My guess its the same OEM camera but PTZoptics have put their branding on it and perhaps developed custom firmware. RE the NDI feature I was not aware of that but will ask. At the moment I don't have a need for that though as it works fine as an RTSP input in VMIX. NDI looks good though.. I did check out Globalmedia also but after shipping and taxes it worked out better getting it from Ebay and the seller accepted an offer:)  That's right. PTZ Optics is a brand belonging to Conference Room Systems, who is simply reseller of gear. Minrray are the OEM. CRS even fronts Minrray.com.  http://www.mingricctv.com/en is the OEMs web site.
 Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
                PFBM wrote:How about NDI support firmware update ?
  Cheers,
  PFBM  I heared new PTZ Optics cameras will support NDI, not, that firmware of older cams will provide that feature.
