Hardware Compatibility
Are the Matrox Graphic Cards compatible with Vmix?
Hi, I bought two Matrox M9188 graphic card and use them for video wall controller. Also I installed Win7 SP1 X64 with DirectX 11 but while opening the VMix I receive this Error: "Graphic Card is not supported. DirectX 9 Compatible Hardware Required." is there any way to solve this problem or I should change my cards? thanks. Sina attached the following image(s):  Vmix Error.png (70kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
I'm in the same boat. Did you get this sorted?
What about adding a DirectX capable card? Don't have one at hand now.
