Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
Hi
Using a dual output VMIX system, internally all set up as a 720/50p system (all Cameras and VT's are natively 720p/50)
EXT1 has all the DSK's (Overlays) Enabled, and is forwarded to our satellite uplink site. (Via HD-SDI) EXT2 has all the DSK's (Overlays) Disabled, is currently being recorded by external Blackmagic Hyperdeck Studio. (Via HD-SDI)
I would like VMIX to internally STREAM the dirty feed presented on EXT1 (When Stream is selected on VMIX) - this is not a problem!
BUT....
I would also like VMIX to internally RECORD the clean feed presented on EXT2 (When Record is selected on VMIX) - so I don't need use the external Blackmagic HyperDeck.
Is there a way I can choose which of the two EXT's are recorded and which of the two EXT's are streamed?
Keith
