Hardware Compatibility
Avermedia StreamEngine, Object reference not set to an instance of an object
I succeded in setting up Vmix x 3 HD cameras using 3 internal video capture devices (blackmagic mini recorder) in my i7 desktop and all is OK. Now, for simpler streamings, I'm trying to use (just one) external device with my i7 laptop (W10) and I have this problem:
-I use AverMedia LGP Lite as a capturing device and Avermedia StreamEngine as a capturing software. -Vmix is 32 bits, as recommended (not 64, the 64 variant is not recognizing the StreamEngine).
I start the Engine, I check "Enable Stream Engine" and if I try to Input -> Camera -> Stream Engine the pop-up mesage says: "AddNewInput Object reference not set to an instance of an object."
Searched about the issue in topics and didn't find relevant answers. Any ideas?
Thx
Do a search for "Live Gamer Portable" and you'll see many posts on this forum regarding using it. Some have had success using the 32bit version of vMix. I have an AverMedia LGP Lite, and have never gotten it to work correctly with vMix, even with enabling Stream Engine and using 32bit vMix. The device works with Wirecast, but is not on the vMix hardware list.
