Ernest Król
#1 Posted : Thursday, November 15, 2012 4:37:40 PM(UTC)
Ernest Król
does vMix support ActionScript in SWF files?
I'm trying to create a score table (with more than two scores) and it would be nice if SWF in vMix can obtain results from web or disk using ActionScript...
#2 Posted : Friday, November 16, 2012 9:20:19 AM(UTC)
vMix uses the same player as Internet Explorer when playing Flash files (SWF).
So as long as you have the latest version of Flash for Internet Explorer installed (32bit or 64bit depending on what version of vMix you are using) then any activescript etc should work fine.
