Stream from vMix to other PC by internet connection
Joined: 10/1/2013(UTC) Posts: 195 ![Man Man](/Themes/yafpro/male.gif) Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
Hello everyone. I wanted to ask if there is the possibility of sending the stream of Vmix to a remote PC , where it is then reproduced the flow
Joined: 12/19/2013(UTC) Posts: 600 ![Man Man](/Themes/yafpro/male.gif) ![Belgium Belgium](/Content/images/flags/BE.png) Location: Belgium Thanks: 75 times Was thanked: 91 time(s) in 75 post(s)
Depending on what you want to achieve, you can use a few services:
With restream.io you can stream to their servers, then stream to anywhere, or to multiple locations.
You can also re stream with wowza or adobe media server. Or if you're handy with scripting using Nginx you can also do it with that.
Vmix unfortunatly doesn't accept a stream directly as an input, it's in the feature requests somewhere, you might bump that one :)
You can also use an IP H.264 decoder. Then take it in as a Camera. Basically using a box to do receive the stream and output it to either SDI or HDMI.
One of the cheapest boxes is a Raspberry PI2.
Speegs
I want to do what is done in this video . Only in this video streaming is done on the same PC , I would like to connect from another computer connected to the Internet , for example from another city
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
Ngix and other RTMP servers can be a pain to set up and configure if you are not used to doing it, Unreal Media has a free media server that is UI based that you can use to set up either a push or pull RTMP server, then it is just a matter of connecting both versions of vmix to it.
Thanks: 29 times Was thanked: 79 time(s) in 50 post(s)
