#1 Posted : Saturday, January 9, 2016 1:07:22 PM(UTC)
I request a 'Shortcut' function and/or button to allow an animated XAML title/graphic to animate "OUT" when used as an 'Overlay' within the 'MultiView' feature.
I have been complacent with the animate "IN" effect for adding in a Penalty Clock to my scoreboard, but the issue really came to light while testing kayllastudio's sample graphic...
(Ref. To this thread: http://forums.vmix.com/d....aspx?g=posts&t=5664 )
I realize there are some workarounds, and I could make it appear to work, but the issue remains and AFAIK there is no way for the XAML to animate "OUT" from within the 'MultiView' feature.
Thanks,
Siroki
#2 Posted : Saturday, January 9, 2016 1:22:24 PM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Thanks,
Do you think on this:
When you put some graphics (like extra time in soccer) on multiview with scoreboard module and when you turn off scoreboard from overlay, the extra time stays and you need to remove it separately?
It won't go away with scoreboard even if its in multiview on scoreboard?
thx
Marko
#3 Posted : Saturday, January 9, 2016 4:05:04 PM(UTC)
@ Siroki
This is about animated XAML graphics that animate "IN" and "OUT".
If used within a 'MultiView' input, there is no "trigger" or means for them to animate "OUT".
To illustrate, as an example, set up a camera input, in MultiView, place the vMix scoreboard somewhere on the screen on "Overlay1".
Next, on "Overlay2" place the vMix animated lower third (in and out animated) in an appropriate spot to compliment the scoreboard as subtext or extra time clock (resize and zoom as necessary). This should animate nicely when you 'take' that input, but there is no way to have the lower third animate out as it was designed.
As indicated, I live with this and simply fade out to another input but it is not the ideal.
