rsuper
#1 Posted : Monday, December 28, 2015 10:57:38 AM(UTC)
rsuper
I'm using the countdown timer to display a countdown to a specific date. However I would like to add the number of days remaining in the countdown.
I tried this format:
Code:
{0:30 December 2015 09:00 PM| dd:HH:mm:ss}
But the "dd" displays the day of the week (4) of the given date it counts to.
How can I add the number of days remaining, or alternatively the total number of hours instead of days? (e.g. 3 days or 72 hours)
rsuper
#2 Posted : Monday, December 28, 2015 11:42:32 AM(UTC)
rsuper
I fixed it myself by creating a Flash overlay which does what I want. I'm still interest in an answer to my question though.
For anyone who understands Actionscript 3 and Flash, this is the code (place it on the timeline):
Code:
import flash.events.Event;
import flash.text.TextField;
var endDate:Date = new Date(2015, 11, 30, 21, 0, 0, 0);
var timer:TextField;
addEventListener(Event.ENTER_FRAME, enterFrame);
function enterFrame(e:Event):void {
	var now:Date = new Date();
	var diff:Number = ( (endDate.time - now.time) / 1000);
	if (diff > 0) {
		var days:int = Math.floor(diff / (3600*24));
		diff %= (3600 * 24);
		var hours:int = Math.floor(diff / 3600);
		diff %= 3600;
		var minutes:int = Math.floor(diff / 60);
		diff %= 60;
		var seconds:int = diff;
		timer.text = zeroPad(days) + ":" +
                     zeroPad(hours) + ":" +
                     zeroPad(minutes) + ":" +
                     zeroPad(seconds);
	else {
		timer.text = "00:00:00:00";
function zeroPad(num:int):String {
	return ("0" + num).substr(-2);
Textfield instance name is assumed to be named 'timer'.
Bardos59
#3 Posted : Monday, December 28, 2015 9:47:44 PM(UTC)
Rank: Guest
Groups: Guests
I tried the code, but I get an error and it does not work....was checking to see what I did wrong, but I get the error "#1065 Variable TCMText is not defined"...
Update: I downloaded a sample clock, did some modification, and got it to work...but I do not know how to upload the file....it works great, and can be modified in Flash....I am not a coder, but I followed the instructions and got it working perfect...even changed the backgrounds and colours....
This is the example and I got it to work Just scroll down to the download button, click and download, uzip, and modify....
http://dl.dropbox.com/u/...ashCountdownTimerAS3.zip
Hope this will help you.
