vMix Crashes after some few hours in Win 10
Hello Since I updated my PC to windows 10 from 7 i have been having the issue of vMix crashing at intervals after some few hours. Its the PC I used for my 24/7 playlist... its an i5 4570CPU, 3.20HGz, 4 Cores 8GB No other software installed on the PC except the vMix and the vScheduler which i have been running on it now for over 1year with no issue until i upgraded to Windows 10. Anybody know any work around this issue... Attached is the error msg i get and i will have to switch off the PC or restart it before i could get it to work again.
Hello Martin
Is there anything you can say to this please or anyone in the house to help?
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
You should return to Windows 8.1......my brother works with an IT company, and he told not to use windows 10 yet, some programs will crash or stall...there are still some bugs to fix.....do a restore to Win 8.1....not an uninstall etc., just do a Restore.....soo what happens
Bardos59 wrote:You should return to Windows 8.1......my brother works with an IT company, and he told not to use windows 10 yet, some programs will crash or stall...there are still some bugs to fix.....do a restore to Win 8.1....not an uninstall etc., just do a Restore.....soo what happens
Thanks for your suggestion...
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 75 time(s) in 57 post(s)
First of all, click on the "details" of the error to find the source of the error. Second, we have many vMix systems on windows 10 working 24/7. so the suggestion of windows 8 is not really that wise. You will be almost forced into windows 10 soon, so the you might as well find the source of the bug now. We also have ours systems loaded with lots of other software i.e. Adobe CC. My guess is that it is with the scheduler app, not vMix, that is why you are not getting much response here.
Good Luck, Steve
stevespaw wrote:First of all, click on the "details" of the error to find the source of the error. Second, we have many vMix systems on windows 10 working 24/7. so the suggestion of windows 8 is not really that wise. You will be almost forced into windows 10 soon, so the you might as well find the source of the bug now. We also have ours systems loaded with lots of other software i.e. Adobe CC. My guess is that it is with the scheduler app, not vMix, that is why you are not getting much response here.
Good Luck, Steve Thank you very much Steve
