Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Hello, Hi, I just bought this controller. Is there a way to keep the lights on and the pad controller with different colors depending on the state of the camera is active or preview? Ok how to assign functions, but if I assign a camera to a button turns off as soon as the release. How can I fix? Thanks so much.
I understad where is the problem, Vmix accept only input on Midi Device. I'm creating a template with Bome Midi Translator and when he's ready I'll be happy to share it. It can affect anyone? And 'just for Akai APC 40 MKII.
Thanks: 7 times Was thanked: 15 time(s) in 14 post(s)
macgiver76 wrote:Hello, Hi, I just bought this controller. Is there a way to keep the lights on and the pad controller with different colors depending on the state of the camera is active or preview? Ok how to assign functions, but if I assign a camera to a button turns off as soon as the release. How can I fix? Thanks so much.
Written for the MK I, but easily adopted to the MK II: http://forums.vmix.com/d....aspx?g=posts&t=5402
Thanks for the reply. I just do not know where to start with this code, you can give me some guidance? It's very interesting! Thank you so much for the availability.
Its written in c#, so you need an IDE to compile it. If the MK I and MK II share the same notes and channels for each of the lights all you should need to change is the device name to find the correct device in the LINQ FirstOrDefault method
even changing the name marks me the name of the device in red, as if it was. thank you
Huh? That didnt translate very well, you mean your IDE is giving an error? if so then there is a typo somewhere.
Sorry but my English is very poor, I help with google. I mean that I have changed the name of the device, but I can not understand how the build, I do not know. I Am downloading Visual Studio Professional 2015, right? Thank you very much for your support. If I can get anything I'll be happy to share it.
You do not need pro, you can use the VS community version which is free.
