marin
#1 Posted : Thursday, December 17, 2015 11:02:47 AM(UTC)
marin
I am using the latest edition of vMix, a HD edition.
I have a problem with my audio source (Blackmagic Design)
When I change the source on some of the sources the BlackMagic AUdio is automaticaly muted.
I change the sources by keyboard shortcut. On some of the sources the audio is working ok, but on some, the audio is automaticaly muted so I have to click on the speaker symbol so I can hear the sound from the Blackmagic card. On each of the sources I am switching I have the BlackMagic card as input in the Multiview section
What should I check and where to look for the problem?
sinc747
#2 Posted : Thursday, December 17, 2015 10:45:05 PM(UTC)
sinc747
Not knowing how you are are setup, I would guess that your solution lies in the Audio Mixer Input (audio from your camera) (from vMix Help -> Audio)
Automatically Mix Audio
Click the Green and Orange Arrow button to enable/disable automatic mixing of audio.
This option is also known as "Follow" on traditional video switchers.
Also may be related to this on the General Tab of your camera input.
Automatically mix audio
By default vMix will automatically swap the active audio to match the active input.
If this box is unticked, vMix will leave the audio as is and any changes will need to be done manually.
Hope this helps.
- Tom
