Error when image Source="{x:Null}"
Joined: 12/3/2013(UTC) Posts: 17  Location: Netherlands Was thanked: 2 time(s) in 2 post(s)
Hi Martin, We are using some empty image fields in our XAML's. (e.g. <Image x:Name="PLAYER_PHOTO" Margin="192,0,0,173.25" Source="{x:Null}" ...) The locations will be set later using the API. In the Title Editor of vMix 16.0.0.92, a popup message shows up when trying to set the image. The message says that the ImageLocation must be set. But that is no problem, because you could still use the Title Editor after closing the message. vMix 16.0.0.92Since we updated to a newer version than 16.0.0.92, a new error message appears when opening the Title Editor. It says that the value cannot be Null. But when you try to close it, it appears again. So we end up restarting vMix. Same XAML in vMix 16.0.0.111Could you please allow image fields to have no source again? Thanks! Brian
