Feature Requests
Luma Key with virtual input
Hi all an other suggestion for you today haha i wanted to put more than one lumakey for the same input but its not working ! I mean i have two lumakey so i create 2 virtual input from my main input and i put 1 lumakey per virtual input but only one working, is it possible to fix that ?
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Not helpful, but can't you use chroma keying instead ? Maybe it would be easier to add your background then...
i cant use chroma cause its not for green screen inscrust i just want to crop some part of the image with luma key to place it whenever i want on the same input ;)
Feature Requests
