guztavo
#1 Posted : Thursday, November 1, 2012 2:37:45 PM(UTC)
guztavo
Hi!
I'm writing because i've made a little software to handle titles on vMix.
You can download here!
It's a test version really basic.
Some things that can do:
-Send tweets from a twitter account to a title
-Handle a count down or a counter for a sport game
-Send a standard information to a title
It's very basic, and has no control of errors, so it can fail.
Please if you are interested or find bugs tell me and i will fix them.
Regards.
thanks 1 user thanked guztavo for this useful post.
kayllastudio on 11/1/2012(UTC)
ClementN
#2 Posted : Thursday, November 1, 2012 3:26:49 PM(UTC)
ClementN
Romania
Good idea, Guztavo!
guztavo
#3 Posted : Thursday, November 1, 2012 3:30:27 PM(UTC)
guztavo
Thanks ClementN!
I do this on my free time (not too much) so it will have a lot of errors but.. hope it helps.
Regards
guztavo
#4 Posted : Thursday, November 1, 2012 5:16:24 PM(UTC)
guztavo
To use remember:
On vMix:
Go to configuration, web, and check the option to activate API. Take note of the URL (i.e. "http://192.168.1.1:8080").
Then go to Titles Handler, put that URL, and set the number of input that you want to handle.
IMPORTANT: Beta version (have bugs). Please test it and give me some feedback.
Regards!!
julianlee
#5 Posted : Thursday, November 1, 2012 9:26:37 PM(UTC)
julianlee
hi, guztavo.
I am very interested in your API S / W.
Download Site Not Working.
If time permits, by e-mail please. (julianlee@hanmail.net)
Best,
julian lee
guztavo
#6 Posted : Thursday, November 1, 2012 9:31:14 PM(UTC)
guztavo
Hi julian!
You can try this option!
Regards!!
ELCHAPIN
#7 Posted : Friday, November 2, 2012 9:05:29 AM(UTC)
ELCHAPIN
Hola gracias
Buen aporte no lo e probado descargando aun .
nesesitamos para la Iglesia unas Biblias que abran y sierren para titulos
BIBLIA ABIERTA , PARA LECTURA y 2 titulos .
NO TRABAJA
Trate de Instalar da error desconocido y no seguro
WIN-7- 64 PREMIUM SPANISH
guztavo
#8 Posted : Friday, November 2, 2012 5:03:50 PM(UTC)
guztavo
Hola ELCHAPIN!
La aplicación está desarrollada y probada sobre Windows XP. Todavía no probé en Windows 7.
De cualquier manera la aplicación lo único que hace es enviar textos a los títulos, no es un generador de títulos animados ni nada por el estilo.
Saludos!
The application was developed and tested over WinXP, and hasn't been tested yet on Win Vista and 7.
Anyway the application only send text to the title input (dont make animated titles or something like that).
Regards!!
ELCHAPIN
#9 Posted : Friday, November 2, 2012 11:12:40 PM(UTC)
ELCHAPIN
AAAAA OK
entendido Gracias
Tnks
PD
No mas XP desde hace 2 años
Guest (9)
