macgiver76
#1 Posted : Monday, November 23, 2015 7:14:47 AM(UTC)
macgiver76
Rank:: Advanced Member
Hello, i have a problem with livestream.
Vmix use with DeckLink Quad and 4 SDI cameras connected. I need to stream the program of Vmix. Set the Virtualcamera of Vmix and set scan source Livestream Vmix Virtualcamera, the preview in ok.
The problem is that Livestream is a scan of the physical devices and correctly sees the four sources of DeckLink Quad, but it stops the video capturing in Vmix.
Livestream software takes control of the DeckLink Quad card and render it unusable in Vmix.
Has anyone had the same problem?
How can I fix?
Thank you.
Sorry for my bad english.
