Maisawka
#1 Posted : Saturday, November 21, 2015 4:34:20 AM(UTC)
Maisawka
Is it possible to switch the camera source from another laptop? i did not use a touch screen laptop, and i need to switch the camera source from the laptop keyboard
I need your help
Thank you
Speegs
#2 Posted : Saturday, November 21, 2015 7:28:56 PM(UTC)
Speegs
I need your help
Thank you
Use the Vmix Web Interface and your mouse. (easy)
OR
Use a Macro so when you hit a key it does the action in the web interface (a little harder)
OR
Script something for Keyboard control using the web API. (harder again)
Start here:
http://www.vmix.com/help...ex.htm?DeveloperAPI.html
Loads of possible things you can do.
Of course writing something to use the Web API gives the best control.
