Hardware Compatibility
Datapath VisionAV AddNewInput error
Joined: 11/19/2015(UTC) Posts: 30  Location: Netherlands Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Hi, When trying to add inputs, vMix 16.x lists my VisionAV - HD video card, but with every selected configuration i get the following error
Capture Device is Not Supported, Device Reported the following:
Capture 32595559-000-0010-8000-00aa00389b71, etc etc
I am using windows 7 or 10 with Datapath 7.8 drivers installed. I tried multiple PC's but all came with the same error.
- Who has such a card working, in witch configuration?
Oscar
I found a solution in downgrading to driver version 7.6 So be aware the latest drivers datapath ships are not supported yet in 16.0.0.106 Oscar
I have same issues with VisionAV HD card. I updated to the most recent driver which is 7.14. And still it gives errors when adding the framecapture card as camera input.
Since VisionAV cards from Datapath are listed as supported cards i would expect it to work.
My Configuration Windows 10 with vMix 17.0.0.110
Does anyone know how to fix this? kind regards Oscar
