preview size resize in vmix16
Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
Hi, just switched from v14 to v16 and I cannot get to reduce preview size so when I have lots on inputs they don't go on too many rows. I tried Auto, various sizes, I can change input size but preview size will not change. thanks.
@ thepelell
Not sure I understand completely. I don't fully remember the scalability of vMix 14, but as near as I can tell, vMix 16 only has 'preset' sizes of the 'Preview' and 'Program' window. Smallest is about 1/3rd of the screen. If you 'right click' and drag the separating line, either up or down, it will click into one of those presets when you cross it. It does not 'scale' in between those spots. (if that is what you mean)
