External vs stream: different audio
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
Hi all,
I'm not good with audio settings, all that A & B buses, audio devices and stuff, so I have a question for more experienced users.
I'd like to have different audio streamed and different audio sent out via external card. Is it possible?
Details
My audio sources are: 1. One audio analog input in my osprey card, I feed it with my mixer sound. There are some microphones connected, they are used by our commentators. 2. One audio from embeded SDI (audio from one of my cameras) 3. Few video clips (video inputs in vMix)
I'd like to stream it all.
At the same time I would like to send external audio & video with Blackmagic DeckLink Mini Monitor card, but WITHOUT our commentators (point 1).
I was thinking about setting sources 1,2&3 to A bus and sources 2&3 to B bus. Then send only B bus to DeckLink card.
Can I do that? If so - how?
The audio bus for streaming and recording is the M(aster) bus. So route 1,2 & 3 to M. Use bus A for the output of 2 & 3 to the Decklink. Go to settings-->audio outputs and set A to the Decklink, then after restarting vMix route 2 & 3 to bus A.
