djevo1
#1 Posted : Monday, November 2, 2015 1:01:50 PM(UTC)
djevo1
Is there anyway to save a preset for multiple stinger transitions. For example I have 5 different stinger transition versions for an event and I would like to call them up without having to go in and manually set duration etc
Kelvin
#2 Posted : Tuesday, November 3, 2015 4:32:52 PM(UTC)
Kelvin
Put all of the stringer videos into a List Input and set the stringer to that input. It should work if all of your stringers are the exact same length. I've experimented with it some, but haven't actually used it in a production.
djevo1
#3 Posted : Tuesday, November 3, 2015 8:44:41 PM(UTC)
djevo1
All the stingers are different lengths and have different cut points
