Logitech c920 Hd webcam Consultation!!!
Hello friends!!!
I need your help! I 'm using a logitech c920 webcam to capture and really works great! My question is few webcam like this could be used in vmix without problems !?
details of the PC:
Intel I7 8GB RAM S.O. win 7 Video card NVIDIA GTX 760 2GB
I hope you can give me a hand as always !!!
Greetings , North
Yes. The issues you will have is the USB Controllers will only support a limited number of Webcams at a time. Also you will have "fun" configuring the properties of each webcam. Have a look at Tom Sinclair's videos to see how it is done. and
Your link Ask is the tail end of the card review. Here is the start... Tom learned of this card by reading my post here... http://forums.vmix.com/d....aspx?g=posts&t=3645I run logitech C270, A MS lifecam studio, a Logitech C920, and a logitech c930e webcam on my card, but then it is also running on a xeon 5680 hexecore processor with a evga GTX 660 video card. Runs much better than it did with the original i7-920 processor installed.
