calamityjane
#1 Posted : Friday, October 16, 2015 5:42:47 PM(UTC)
calamityjane
A. when I choose to use the MIDI controller rather than the keyboard for shortcuts, (for SET TEXT as an example)the option for entering the "value" does not appear.
I found a "workaround" for the NO VALUE field when using the MIDI controller.
1. Set the shortcut using a selection from the keyboard.
2. Edit this shortcut and change the trigger to something from the MIDI controller
It works. Not elegant but it works
B. Please design it so a fader from the Korg or any MIDI controller can be used to reset/adjust the TIME in a scoreboard. For that matter so another fader can be used to increase/decrease score by SET TEXT as you slide the FADER up or down.
Whit
