Hello, In the post http://forums.vmix.com/d....aspx?g=posts&t=1359 It got the tip to install the 32 bit version. I have a 64 bit laptop. Two questions: 1. What is the difference between a 32 or 64 bit version on a 64 bit laptop. What is not possible? 2. I can't find the download 32 bit version anywhere... I'v looked everywhere. Sorry. Rgds, Daan
Thanks: 10 times Was thanked: 4 time(s) in 4 post(s)
When you install vMix both 64 bit and 32 bit are installed. The installer creates a start menu folder for vMix and under it you find vMix and vMix (x64). If you are running the shortcut just called vMix you are running 32 bit. For the laptop, 64 bit is better as it will use the resources better. However, certain programs, capture cards, etch will require you to run 32 bit in order for vMix to be able to work with them.
