Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
Hello i find a little bug, if you start recording with ffmpeg, prores or h.264 422 for example, and later start the streaming the record stop. in the log not said nothing Code:ffmpeg started on 2015-09-22 at 22:04:04
Report written to "e:\grabaciones\prueba - 22 septiembre 2015 - 10-04-04 .mp4.log"
Command line:
"C:\\Program Files (x86)\\vMix_16\\streaming\\ffmpeg.exe" -report -y -f asf -i "\\\\.\\pipe\\65662bb5-ad88-4d61-bdd4-2780d5d1f3ce" -r 25 -vcodec libx264 -preset:v veryfast -b:v 50M -acodec libfaac -b:a 384k -f mp4 "e:\\grabaciones\\prueba - 22 septiembre 2015 - 10-04-04 .mp4"
ffmpeg version 2.6.git Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686
libavutil 54. 27.100 / 54. 27.100
libavcodec 56. 46.100 / 56. 46.100
libavformat 56. 40.100 / 56. 40.100
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 19.100 / 5. 19.100
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.100 / 1. 2.100
libpostproc 53. 3.100 / 53. 3.100
[asf @ 01f7f9c0] Stream #0: not enough frames to estimate rate; consider increasing probesize
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, asf, from '\\.\pipe\65662bb5-ad88-4d61-bdd4-2780d5d1f3ce':
Metadata:
DeviceConformanceTemplate: @
WMFSDKNeeded : 0.0.0.0000
WMFSDKVersion : 12.0.7601.17514
IsVBR : 0
Duration: N/A, start: 0.000000, bitrate: 29184 kb/s
Stream #0:0(spa): Video: rawvideo (UYVY / 0x59565955), uyvy422, 1920x1080, 27648 kb/s, 1k tbr, 1k tbn, 1k tbc
Stream #0:1(spa): Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, 2 channels, s16, 1536 kb/s
No pixel format specified, yuv422p for H.264 encoding chosen.
Use -pix_fmt yuv420p for compatibility with outdated media players.
[libx264 @ 01bddc00] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 01bddc00] profile High 4:2:2, level 4.1, 4:2:2 8-bit
[libx264 @ 01bddc00] 264 - core 144 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=2 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=12 lookahead_threads=4 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=abr mbtree=1 bitrate=50000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
Output #0, mp4, to 'e:\grabaciones\prueba - 22 septiembre 2015 - 10-04-04 .mp4':
Metadata:
IsVBR : 0
encoder : Lavf56.40.100
Stream #0:0(spa): Video: h264 (libx264) ([33][0][0][0] / 0x0021), yuv422p, 1920x1080, q=-1--1, 50000 kb/s, 25 fps, 12800 tbn, 25 tbc
Metadata:
encoder : Lavc56.46.100 libx264
Stream #0:1(spa): Audio: aac (libfaac) ([64][0][0][0] / 0x0040), 48000 Hz, stereo, s16, 384 kb/s
Metadata:
encoder : Lavc56.46.100 libfaac
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (libfaac))
Press [q] to stop, [?] for help
frame= 17 fps=0.0 q=0.0 size= 0kB time=00:00:00.57 bitrate= 0.7kbits/s
frame= 30 fps= 29 q=4.0 size= 531kB time=00:00:01.08 bitrate=4011.8kbits/s
frame= 43 fps= 28 q=0.0 size= 540kB time=00:00:01.61 bitrate=2732.3kbits/s
frame= 56 fps= 27 q=0.0 size= 551kB time=00:00:02.13 bitrate=2117.5kbits/s
frame= 69 fps= 27 q=0.0 size= 561kB time=00:00:02.64 bitrate=1739.8kbits/s
frame= 82 fps= 26 q=0.0 size= 572kB time=00:00:03.15 bitrate=1484.4kbits/s
frame= 95 fps= 26 q=0.0 size= 582kB time=00:00:03.68 bitrate=1292.8kbits/s
frame= 108 fps= 26 q=0.0 size= 593kB time=00:00:04.22 bitrate=1150.5kbits/s
