op music
#1 Posted : Tuesday, September 15, 2015 8:00:11 AM(UTC)
op music
Hi, I need some advice, I need a capture card with 4 inputs that work with sd Vmix, but very economical, any suggestions? I have already tried with easycap but I can not put more than 2 cards, thanks
i7 8gb ram win 7/8
#2 Posted : Tuesday, September 15, 2015 11:01:29 AM(UTC)
@ op music
What is your definition of "economical"?
Without knowing more about your system's capabilities and your budget, the best bang for your buck on SD capture is the Magewell capture box:
http://www.magewell.com
http://www.bhphotovideo....b_6_channel_usb_3_0.html
op music on 9/15/2015(UTC)
Similar Topics
Capture card with 4 inputs sd economic (Hardware Compatibility)
by op music 8/31/2014 4:51:18 AM(UTC)
