AlanZ
#1 Posted : Monday, September 14, 2015 1:49:25 PM(UTC)
AlanZ
I am making fine progress tweaking a Korg nanoKontrol2 unit with vmix.
I run into some issues that I could use some help with.
I am using channel dial pots and sliders to set the panx and pany for each of the camera inputs.
I want to assign a button press (perhaps the mute button on one of the 8 channels) to SetPanX to 0 and another button to SetPanY to 0 for the Active window.
Although I can do this easily with regular keyboard keys (it allows me to set the 0 value), I don't have the option to set a fixed value on the midi controller keypress.
I don't know if it's because the buttons are velocity sensitive, but when I click the button, the pan goes all the way to one side, resulting in a black screen.
I tried using advance to have the button press link to the existing keyboard shortcut, but so far I have had no luck.
Maybe I am missing something with the chaining of shortcuts.
Any help is appreciated.
