Ash
#1 Posted : Sunday, September 13, 2015 6:18:25 PM(UTC)
Ash
Was thanked: 11 time(s) in 8 post(s)
Hi
Streaming with 2 cams at game, but cam1 did not initially record. Cam2 ok.
Camera 1 did not create a file at all but cam 2 did.
Both cameras were functioning ok in vMix i.e. could preview, output and switch as normal.
I closed down Replay while game going and reset twice and eventually camera 1 started recording to disk around 12 - 13 mins after camera 2 started (according to file system).
I have 2 cameras a number of times before and setup as usual using vMix 15. First time with vMix 16
at around 29:50 was first attempt at replay after goal. Stinger initiated as per normal but no replay as there was no file.
I had triggers setup for the replay on 'A'.
vMix 16.0.0.71
Ash attached the following image(s):
#2 Posted : Monday, September 14, 2015 3:54:37 AM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
There should be a log file in the replay directory that might indicate what happened with the first camera recording.
Ash
#3 Posted : Monday, September 14, 2015 5:22:39 AM(UTC)
Ash
I have 3 logs
Log 1
2015-09-12 12:52:42,ConfiguredAudio: 5
2015-09-12 12:52:42, SampleRate: 48000
2015-09-12 12:52:42, BitRate: 16
2015-09-12 12:52:42, Channels: 2
2015-09-12 12:52:42, Float: False
2015-09-12 12:52:42, Delay: 20
2015-09-12 12:52:43,ConfiguredCamera: 1
2015-09-12 12:52:43, Format: Uyvy
2015-09-12 12:52:43, Pitch: 2560
2015-09-12 12:52:43, SampleRate: 48000
2015-09-12 12:52:43, BitRate: 16
2015-09-12 12:52:43, Channels: 2
2015-09-12 12:52:43, Float: False
2015-09-12 12:52:43, Delay: 0
2015-09-12 12:52:43,ConfiguredCamera: 2
2015-09-12 12:52:43, Format: Yuy2
2015-09-12 13:56:00,StartRecording
2015-09-12 13:56:00, Cameras: 2
2015-09-12 13:56:00, Size: {Width=1280, Height=720}
2015-09-12 13:56:00, FrameRate: 50
2015-09-12 13:56:00, Interlaced: Progressive
2015-09-12 14:09:08,StopRecording
Log 2
2015-09-12 14:09:22,ConfiguredAudio: 5
2015-09-12 14:09:22, SampleRate: 48000
2015-09-12 14:09:22, BitRate: 16
2015-09-12 14:09:22, Channels: 2
2015-09-12 14:09:22, Float: False
2015-09-12 14:09:22, Delay: 20
2015-09-12 14:09:22,ConfiguredCamera: 1
2015-09-12 14:09:22, Format: Uyvy
2015-09-12 14:09:22, Pitch: 2560
2015-09-12 14:09:22, Delay: 0
2015-09-12 14:09:22,ConfiguredCamera: 2
2015-09-12 14:09:22, Format: Yuy2
2015-09-12 14:09:24,StartRecording
2015-09-12 14:09:24, Cameras: 2
2015-09-12 14:09:24, Size: {Width=1280, Height=720}
2015-09-12 14:09:24, FrameRate: 50
2015-09-12 14:09:24, Interlaced: Progressive
2015-09-12 14:09:59,StopRecording
2015-09-12 14:09:59,Statistics
2015-09-12 14:09:59, Camera 1
2015-09-12 14:09:59, Dropped Frames
2015-09-12 14:09:59, -DueToCPUOrDisk: 0
2015-09-12 14:09:59, -SourceTooSlow: 0
2015-09-12 14:09:59, -SourceTooFast: 0
2015-09-12 14:09:59, -AVSync: 0
2015-09-12 14:09:59, Total: 0
2015-09-12 14:09:59, Dropped Samples
Log 3
2015-09-12 14:10:34,ConfiguredAudio: 5
2015-09-12 14:10:34, SampleRate: 48000
2015-09-12 14:10:34, BitRate: 16
2015-09-12 14:10:34, Channels: 2
2015-09-12 14:10:34, Float: False
2015-09-12 14:10:34, Delay: 20
2015-09-12 14:10:34,ConfiguredCamera: 1
2015-09-12 14:10:34, Format: Uyvy
2015-09-12 14:10:34, Pitch: 2560
2015-09-12 14:10:34, Delay: 0
2015-09-12 14:10:38,StartRecording
2015-09-12 14:10:38, Cameras: 1
2015-09-12 14:10:38, Size: {Width=1280, Height=720}
2015-09-12 14:10:38, FrameRate: 50
2015-09-12 14:10:38, Interlaced: Progressive
2015-09-12 14:11:29,StopRecording
2015-09-12 14:11:29,Statistics
2015-09-12 14:11:29, Camera 1
2015-09-12 14:11:29, Dropped Frames
2015-09-12 14:11:29, -DueToCPUOrDisk: 0
2015-09-12 14:11:29, -SourceTooSlow: 0
2015-09-12 14:11:29, -SourceTooFast: 0
2015-09-12 14:11:29, -AVSync: 0
2015-09-12 14:11:29, Total: 0
2015-09-12 14:11:29, Dropped Samples
2015-09-12 14:11:29, -DueToCPUDOrDisk: 0
2015-09-12 14:11:29, Camera 5
2015-09-12 14:11:40,ConfiguredCamera: 2
2015-09-12 14:11:40, Format: Yuy2
2015-09-12 14:11:40, Pitch: 2560
2015-09-12 14:11:40, SampleRate: 48000
2015-09-12 14:11:40, BitRate: 16
2015-09-12 14:11:40, Channels: 2
2015-09-12 14:11:40, Float: False
2015-09-12 14:11:40, Delay: 0
2015-09-12 14:11:44,StartRecording
2015-09-12 14:11:44, Cameras: 2
2015-09-12 14:11:44, Size: {Width=1280, Height=720}
2015-09-12 14:11:44, FrameRate: 50
2015-09-12 14:11:44, Interlaced: Progressive
2015-09-12 14:14:00,StopRecording
2015-09-12 14:14:00,Statistics
2015-09-12 14:14:00, Camera 1
2015-09-12 14:14:00, Dropped Frames
2015-09-12 14:14:00, -DueToCPUOrDisk: 0
2015-09-12 14:14:00, -SourceTooSlow: 0
2015-09-12 14:14:00, -SourceTooFast: 0
2015-09-12 14:14:00, -AVSync: 0
2015-09-12 14:14:00, Total: 0
2015-09-12 14:14:00, Dropped Samples
2015-09-12 14:14:00, -DueToCPUDOrDisk: 0
2015-09-12 14:14:00, Camera 2
2015-09-12 14:14:00, Camera 5
2015-09-12 14:14:07,StartRecording
2015-09-12 14:14:07, Cameras: 2
2015-09-12 14:14:07, Size: {Width=1280, Height=720}
2015-09-12 14:14:07, FrameRate: 50
2015-09-12 14:14:07, Interlaced: Progressive
2015-09-12 14:15:48,StopRecording
2015-09-12 14:15:48,Statistics
2015-09-12 14:15:48, Camera 1
2015-09-12 14:15:48, Dropped Frames
2015-09-12 14:15:48, -DueToCPUOrDisk: 0
2015-09-12 14:15:48, -SourceTooSlow: 0
2015-09-12 14:15:48, -SourceTooFast: 0
2015-09-12 14:15:48, -AVSync: 0
2015-09-12 14:15:48, Total: 0
2015-09-12 14:15:48, Dropped Samples
2015-09-12 14:15:48, -DueToCPUDOrDisk: 0
2015-09-12 14:15:48, Camera 2
2015-09-12 14:15:48, Camera 5
2015-09-12 14:16:21,StartRecording
2015-09-12 14:16:21, Cameras: 2
2015-09-12 14:16:21, Size: {Width=1280, Height=720}
2015-09-12 14:16:21, FrameRate: 50
2015-09-12 14:16:21, Interlaced: Progressive
2015-09-12 14:36:21,NewSegment
2015-09-12 14:56:21,NewSegment
2015-09-12 15:16:21,NewSegment
2015-09-12 15:36:21,NewSegment
2015-09-12 15:56:21,NewSegment
2015-09-12 16:06:36,StopRecording
2015-09-12 16:06:36,Statistics
2015-09-12 16:06:36, Camera 1
2015-09-12 16:06:36, Dropped Frames
2015-09-12 16:06:36, -DueToCPUOrDisk: 0
2015-09-12 16:06:36, -SourceTooSlow: 2
2015-09-12 16:06:36, -SourceTooFast: 0
2015-09-12 16:06:36, -AVSync: 0
2015-09-12 16:06:36, Total: 2
2015-09-12 16:06:36, Dropped Samples
2015-09-12 16:06:36, -SourceTooSlow: 0
2015-09-12 16:06:36, -DueToCPUDOrDisk: 0
2015-09-12 16:06:36, Total: 0
2015-09-12 16:06:36, Camera 2
2015-09-12 16:06:36, -SourceTooSlow: 1
2015-09-12 16:06:36, Total: 1
2015-09-12 16:06:36, Camera 5
#4 Posted: : Monday, September 14, 2015 5:30:13 AM(UTC)
What sort of capture hardware is being used for the two cameras.
The log says UYVY for one and YUY2 for the other, so that might be related.
vMix Replay generally requires cameras coming from the same timing source which sometimes
means cards from different manufacturers will not work together.
Ash
#5 Posted : Monday, September 14, 2015 7:43:23 AM(UTC)
Ash
Magewell Quad SDI
But both cams use HDMI out and the HDMI to SDI are different.
I will connect up and recheck the defaults and then try an adjustment in the Input -> Camera -> Video Format
