AlanZ
#1 Posted : Saturday, September 12, 2015 10:09:10 AM(UTC)
AlanZ
I would like to be able to use shortcuts key to switch between different vmix saved presets.
Is this possible, or do I need to use an external keyboard macro tool (like AutoHotKey)?
Ideally, I would like a keypress to load a named preset file and accept its default selections.
Any thoughts?
AlanZ
#2 Posted : Tuesday, September 15, 2015 9:19:47 PM(UTC)
AlanZ
Anyone?
richardgatarski
#3 Posted : Wednesday, September 16, 2015 4:38:02 AM(UTC)
richardgatarski
Was thanked: 298 time(s) in 251 post(s)
AlanZ,
I don't want to be unpolite, but it is easy for anyone to check the help file and find that it is not possible.
In recent versions (at least from v15 and onwards) there is a dropdown for Open, then select one of the recent presets.
If you need a shortcut (presumably for API calls), then file a Feature Request.
Thanks.
AlanZ
#4 Posted : Wednesday, September 16, 2015 5:39:22 AM(UTC)
AlanZ
With all due respect, I did check the help files and looked through all of the shortcut actions.
That is the reason I asked the question, to see if I missed anything, or was not understanding something.
If the answer is "no, you can't currently do that", then I will enter a feature request.
