waldron18
#1 Posted: : Friday, September 11, 2015 12:11:14 AM(UTC)
waldron18
Hi
I seem to be having an issue when I have any mac connected to vmix there is a bit of a lag in the mouse cursor or video playing. It just doesn't seem very smooth. I've tried different resolutions etc but no difference.
Not sure if it's a mac issue or vmix issue but just thought I'd see if anyone else has experienced it? It's not heaps, it's just not a nice smooth flowing capture. Could be a mac display port thing.
I've tested an iMac, Macbook and Macbook Pro... all do the same.
Cheers
Len56
#2 Posted : Friday, September 11, 2015 1:24:00 PM(UTC)
Len56
waldron18 wrote:
Hi
Cheers
waldron18,
Sorry but I forgot to mention that the medical driver for your YUAN card you downloaded and installed is the problem I am getting the same problem with my MacBook pro, if you were to go back to the non medical driver from the YUAN website you wont get that problem but you wont be able to bring your Macs into vMix because of the HDPC problem. I did have a word with the person I bought the card from and he did have a word with the YUAN technical team but nothing was done about it.
I did try to input a camera into my BM intensity pro card and everything worked fine, so I do think it is the yuan medical driver causing the problem with the lag.
