I recorded 13 episodes of a study with the new VMIX 16. I Recorded this with FFMPEG, Pro Res, MOV. Now i read on the forum that for the best compatible i had to use MOV Indexed. So, now i have files with the normal MOV files. And i have problems with opening, editing and converting.
Does anyone has a option for a good program to open these files and convert them in another format, so that i can use them in e.g. Final Cut Pro.
I'll hope someone can help me,
With kind regards,
Alfred
Try Format Factory or Handbrake.
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
We should probably make a MOV indexing utility as a vMix utility, but until then it's easy to use ffmpeg to quickly index existing MOV files for editing. To do this download ffmpeg and open a command prompt to run the following command: Quote:ffmpeg.exe -i recording.mov -vcodec copy -acodec copy convertedrecording.mov
admin wrote:We should probably make a MOV indexing utility as a vMix utility, but until then it's easy to use ffmpeg to quickly index existing MOV files for editing. To do this download ffmpeg and open a command prompt to run the following command: Quote:ffmpeg.exe -i recording.mov -vcodec copy -acodec copy convertedrecording.mov Okey, i tried to use ffmpeg, but i don't now how it works and i'm not so into all the systems with codes etc. Is there another solution? I tried QuickTime Player, AVS and MPEG Streamclip to export the file, but all were given an error.
Groups: Joined: 9/15/2013(UTC) Posts: 168  Location: Barbados Thanks: 14 times Was thanked: 14 time(s) in 13 post(s)
I did 4 hours recording in Magic .avi, and now I can not edit or play back in mwdia player, VLC QT, nothing...I get only audio in media and VLC players....I tried playing back in vMix and it played but will not open in Edius...any help would be appriciated
