Countdown setting error in Windows 10?
Joined: 7/6/2013(UTC) Posts: 45   Location: Slangor Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
I tried to open the scoreboard in the title editor to football. after my set at Countdows setting, it turns out after 59:00 minutes back to 0:00. Is there a solution?
@ sontoloyo Not sure what is causing your issue, but mine seems to work fine in Windows 10, as described in this post: http://forums.vmix.com.a...ts&m=16481#post16481I can't imagine it has anything to do with your computer clock settings but I did notice yours to be 24 hour and not am & pm like mine, perhaps it's a clue, other than that I don't know. Ice
Thanks Ice, Now the problem is resolved. lies in decimal separation time between (mm.ss) and (mm: ss) in windows time/date setting.
