Please suggest a midi device as pointer
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
Anyone know if such a device even exist? A presentation pointer that send MIDI to computer instead of keystokes.
I want to use a midi solution becasue the traditional keystoke pointers needs the program (vMix or PPT) to be in focus to get the command while the midi commands works even when the vMix window is not in focus.
That way, there will be much freedom for the operator while the speaker change the slides from the stage.
Thank you,
