waldron18
#1 Posted : Sunday, August 9, 2015 8:47:33 PM(UTC)
waldron18
Hi
I'm wanting to achieve the following and I have two pcie ports available on my motherboard. I'm confused which cards can support input and output simultaneously.
For example I'd like to have 3 HDSDI inputs & 3 HDMI inputs, then HDSDI out and HDMI output.
I was looking at the AJA LHI card and thought I could maybe get two? Does the card and Vmix allow simultaneous input from different sources and then program output through the same card?
Any other suggestions? I'm on a budget too. :-)
With the KHLi-Box breakout box, does that allow for more simultaneous input/output or only one at a time?
This is confusing!! haha
