Feature Requests
vMix connection across network
Martin, I am very happy all the new features of this release. I want to ask you if it is possible to implement a new feature where vmix can do streaming to another vmix (TX / RX)  Example:   I am currently connecting two studies ubiquiti point links using the VLC and RTSP point, but I would like that this was native option as vMix using the VLC plugin.  Thank you in advance for taking into consideration this new feature which is very helpful when our main study vMix use as a primary mixer and the mobile studio vMix used for different events.
 1 user thanked agmedia for this useful post.
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
 1 user thanked ClementN for this useful post.
+1 as well. We are often asked to to do 2 or more stages of a festival, and switch between them. This could be done in our office, if all stages are streaming to a vmix. We currently have a second setup that is allmost finished, and are already looking out for a third one.
What would be completely awesome, is if we could stream to a vmix machine, that is able to switch in between streams, but also sends the 'clean' streams seperatly towards our CDN. This way we could offer our public the choice to watch 1 stream, or the 'combined stream' with highlights.
 1 user thanked Ittaidv for this useful post.
+1 Not sure if this feature has actually been formally requested before. But it has certainly been discussed and asked for in a number of topics over the years. One alternative is to use Teradek's Cubelets (a set of Cube Encoder and Decoder), which is rather expensive. And also demands video (HDMI/SDI) output and input cards from the sending and the receiving vMix PCs. (Actually, depending on how things are setup, it is possible to use a Stream Input in vMix to receive the stream from a Cube Encoder, depending on how it is configured). If implemented, perhaps this would also fullfull the parallell feature request to receive streams from a Smartphone camera.
Groups: Guests
+1
I use workaround - in remote PC's i start vMix for getting signal from videocam's (HDMI/SDI with capture card), and vMix desktop capture to grab "fullscreen". In main machine i get and mix remote desktops and send it to CDN. But - all machines will be in same network (my town provider create special VLAN for me), or get real-IP. And speed of LAN will be big. I work with desktop resolutions 1280x720 and take ~20-25 fps on 100Mbit/s channels. For serious application it is not good variant.
As variant - support Syphon (Spout) as "external" output.
Groups: Guests
+1
Another good variant - create new profiles in streaming options which equal options in streaming inputs - TS over UDP, TCP,TCP Pull. And vMix may be used as poin-to-poin or multipoint videoconference system... (2 vmix hosts - - vmix1-TS or RTMP->vmix2 and vmix2-TS or RTMP->vmix1)
+1
In my city we want to connect multiple venues together (mesh)
You can also just put a RTMP streaming server into your network design or run on one of the Vmix computers if you have enough resources. Latency is not low using this method.
Maybe just allowing VMix Computer A's output to be a desktop capture source over IP (not restricted to the same LAN) for Vmix Computer B is the solution.
Of course a nice link would be required.
Feature Requests
