Joined: 8/5/2015(UTC) Posts: 16 Location: Milton Keynes,UK
Hello, first time posting here :)
In the API that comes back, there's a section <transitions><transition number="1" effect="Fade" duration="500"/> <transition number="2" effect="Fly" duration="500"/> <transition number="3" effect="Fade" duration="500"/> <transition number="4" effect="CubeZoom" duration="1000"/></transitions>
These seem to be set in stone. There's a vague suggestion somewhere that a duration can be set for transitions. However the shortcuts for transition1-4 don't have any parameters, any parameters are ignored, or at least I can't fathom the syntax.
So.. is there a way through the API of setting transition durations? Especitally for the transition 1 to 4?
Also.. the current zoom for an input isn't being returned in the API... nor the panx-y values.
Thanks Geoff.
