Lzrd
#1 Posted : Wednesday, August 5, 2015 3:01:25 AM(UTC)
Lzrd
I use 1080 50i input, but when shooting sports I get motion blur. I've tried different output settings, different deinterlace methods (blend, discard), but don't get good result.
What configuration do you use to get best result? I stream to youtube (720, 30fps).
#2 Posted : Wednesday, August 5, 2015 6:13:05 AM(UTC)
Was thanked: 4752 time(s) in 1632 post(s)
Selecting Discard as the Camera deinterlacing method in Settings should remove the motion blur from 50i video.
What sort of capture card and camera is being used? Maybe the card is doing its own deinterlacing before sending the video to vMix.
As for 30fps output, I would recommend changing this to 25 to match the camera, as there is no 100% smooth conversion between 50i and 30fps.
Hope this helps.
Lzrd
#3 Posted : Thursday, August 6, 2015 2:27:34 AM(UTC)
Lzrd
I use Canon XHG1 camera and BM duo and studio for capture. No deinterlacing is set on capture cards.
Master frame rate 50i PAL; Camera/playback: discard;
I record .TS 25 fps or 50i, but it looks same.
