Recorder solution (back-up)
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
As a back-up solution I am thinking to double the recording step and add a another recorder along with the vMix one.
Anyone can recommend a software recorder that can record the video from "vMix Virtual Capture" and it is strong enough to relay on it?
Thank you very much,
Joined: 2/6/2011(UTC) Posts: 79  Location: Belgium Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
i recommend Debut too... already use it and works nice.
Thank you very much Luc and Melody
