Feature Requests
Larger Buttons in BASIC View for touch screen use
Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
We are using vMix with a touch screen. We make extensive use of the six coloured pallets to the left of the inputs. Thanks to these colour pallets we can visually select 6 x 24 inputs without having to scroll. The only issue is these six coloured selectors are so small they are almost impossible to target with a touch screen. Would it be possible to make them bigger in BASIC mode, and thus make it easier for touch screen users.
Additional 'Accessibility' features, would be to reorganise the 'options' available on each input when in BASIC mode. Replacing Close, Quick Play, Cul Loop and Play with bigger LOOP CUT PLAY - we don't need to close an input when in BASIC mode.
Can the selection of the pallets be made via the API? If that is possible I could build an external Salvo box to select the pallets.
Best Regards
Keith
Feature Requests
